With an unpaid account, images have to be hosted on another website and IMG tags used to reference the URL.It is also important to understand that one stone can have different results on the same steel depending on how you dress it.
My new PDT CBN stones ground like a new, insanely scratched mirror, even after a 15,000 grid (1/0 micron) grit.
But I adjusted them by dripping industrial diamond slurry with a grain size of 0.25-0.5 microns onto them and grinding two stones (15,000 and 10,000) against each other for about a minute. Then I washed the stones and dressed them again under running water with Naniwa 12000 nagura just to remove any loose grain residue on the surface.
Now the stones sharpen so that only a few hairline scratches are visible on the entire blade, which can only be seen at the right angle of light.
However, it is still not the same result as with Dr. Marv stones in terms of the mirror finish on the edge.
Of course, there is always room for improvement. I know this because I work in the optical industry, where we grind tungsten carbide to tolerances below 10 nanometers, which is also a mirror, but it seems unnatural to the human eye. It no longer looks like a mirror, but rather a window into another dimension.
I would like to ask the moderator how many posts I need to make on this forum before I am allowed to post images?
While I fully understand that this site owes its long standing existence to the steady diet of threads titled “Which fixed blade to baton through the crankshaft of my small block Chevy engine?”, it’s the discussions like this one that have kept me a huge fan of Bladeforums for over a quarter century. Pushing the limits of our sharpening abilities is a never ending pursuit, but ultimately a fun and rewarding one. Thanks to D Diemaker and B -BaRD- for generously sharing your time and wealth of information.
Is there one chart out there you guys would recommend as the most accurate for converting micron size to grit values, in the specific context of blade sharpening, at least? A quick Google search will reveal thousands of such charts, but the discrepancies from one to the next can be truly monumental.
I will also show the results of experiments using Dr. Marv 0.5 micron stone. After 1 micron stone, it is practically impossible to use. Both surfaces rubbing against each other are so smooth that a phenomenon called adhesion occurs and the diamond tears pieces of material out of the steel.
So I tried to roughen the 0.5 stone using an electroplated 80-grit plate, but without success.
So I tried leaving the rough edge surface and, after 10-micron grit, I immediately ground it with a 0.5-micron Dr. Marv stone.
The result is absolutely fantastic sharpness.
Better than after the entire sequence of stones from 10 microns to 1 micron.
To give you an idea, a colleague of mine gave me one of her hairs. I dropped it on the blade and it got stuck on the edge. When I blew on it, it cut through.
S35VN
Dr. Marv recommends gently dressing the stones with an Atoma F400 diamond plate under a constant flow of lukewarm water. He also recommends that, before using the Atoma plate in this capacity for the first time, you give it a vigorous rub down all over its surface with an old knife or annealed (ideally) steel rod, again under running water, ensuring that it’s fully cleaned before using it on his stones. He’s generally pleased with the quality and purity of the Atoma plates, but this quick precaution will provide an extra measure of security to ensure that his stones aren’t cross contaminated.
Unfortunately, I don't have any plated stones that are not totally worn out. But the idea of using plated diamonds to dress resin bond diamonds does send a shiver down my spine. It will take the points off the plated diamonds. I have yet to detect contamination from dressing and have looked for it in both the stones and scratches on the bevel, so I question if this is an issue. Still, I figure I will try dressing on a plated stone at some point to see what it does. I did find it interesting that Dr. Marvin found that using sandpaper stripped the diamonds from the surface of his stones, which I think does the same for mine due to how well they work after dressing them on sandpaper.From Dr Marv's recommendation toBronco and what B -BaRD- has experienced in trying to condition the stones, I'm wondering if Dr Marv's superior performance mostly lies in how careful he is in preparing the surface of his stones to avoid any and all cross contamination.
D Diemaker , your stones are phenomenal quality stones. I wonder if you won't get a very similar level of performance if you try preparing a set the same way as Dr Marv does by being hyper critical about cross contamination. Maybe try preparing a newly made set with a slightly used 400 Atoma plate to see what happens?
