Mjolnir,
Thanks for the interest.
I prefer not to compare our knives to others, I prefer that our work stand on its own merits.
With that said... the highlights of our knives are:
* Lifetime guarantee
* extremely functional, field tested, design
* very high quality materials (3V steel, Linen Micarta, leather sheaths, etc.). We simply do not cut ANY corners.
* a "controlled" design, manufacturing and heat treat process from start to finish. Our blade design does not have any stress points, during manufacturing the blade is rarely above room temperature, and an "involved" heat treat process (3 days) that guarantee's the absolute best qualities of the steel.
* Very high level of craftsmanship. Our work rivals any semi-custom maker that I am aware of.
* super comfortable, handles. not only has the contours of our handles been worked and reworked to settle on a very useable "interface" but they also feature rubber gaskets that cushion shock when chopping, Forward and reverse "grooved" thumb ramps, and index and forward choils for multiple grips
* wickedly sharp... and they stay that way for a LONG time. All knives are hand sharpened and stropped before leaving our shop.
* unique hybrid tanto tip offers the utility of a tanto but enough belly for effective slicing.
* full flat grind, but unique 3-D grind on the tip for improved tip durability
* Available as black or satin.
* well balanced... our knives feel "lively" in the hand.
* Tool & Die quality from start to finish.
Thats what comes quickly to mind anyway.
If you get a chance to go to the Blade show, you can handle our knives at "2theHilt's" booth! I believe once you handle our work you won't be disappointed.
Hope that helps,
Eric Fehrman
