Cliff Stamp
BANNED
- Oct 5, 1998
not2sharp :
After working with the Wildlife Hatchet from GB for awhile I could get about two inches of penetration on clear fresh pine, a soft wood. The Forest axe was only slightly deeper. Now the face is significantly wider, and taking this into account the penetration from an area perspective (amount of wood cut), is less than double.
On the same type of wood the top international ax men (well they are all from Australia or New Zealand) get between two and three inches of penetration across a six inch face. The upper limit of three is only met by the very top in the world, using very heavy axes. Considering that I don't rate myself on the same level in terms of hatchet use, the upper level isn't a fair comparion anyway.
Just consider that an axe ten times as powerful as the hatchet would get ten inches of penetration. No axe even has a head that deep. Even five times yeilds more than five inches of penetration which would allow you to cleave down twelve inch trees in a few swings. You could easily then out race a large chainsaw.
Longer axes, and heavier heads have lots of advantages.They allow you to cut much closer to the ground, and use a much less energetic swing which is much wider, as you let the weight of the head do the work and there is little follow through which is very heavy with a hatchet. Using an axe is mainly cardio while a hatchet is very muscle fatiguing on the hand, wrist and forearm.
-Cliff
I would suspect that the momentum gained from the leverage of a longer haft would very significantly increase the amount of power generated.
-Cliff
