- Jan 1, 2009
Well, I'm going to ask for help anyway. Trying to add 1095 HT to our offerings. We did some in the past and some of you may remember my thread with the unintended hamon line. That was queched in canola.
I decided to get a proper oil and hope for better results. I got Houghton Quench K - a 9 second oil like parks 50. First tests were with some O1 blades and they turned out great. Next was a 1/4" thick 1095 chopper and it looked great, but Rockwelled in the mid 40's.
Using ATP641 antiscale - into the evenheat at 1500 degrees - previously double checked with digital pyrometer - 10 minutes to equalize and ten minutes at temp. Out fast to the quench pail right below the oven - stabbed in quickly and then 'sliced' back and forth (not side to side) for 30 seconds before peeking (5 seconds - it's straight) and back in till hand cool. Scrubbed off the last bits of ATP641 and into the Rockwell tester.
It should be 65 or so (I'm not one to split hairs or infer tester accuracy beyond what may be there). It's reading consistently in the mid 40's
Did it again - bumped to 1525 soak. Same results.
Took a sample of the same steel (From Admiral) to make sure the maker hadn't mixed up some steel bars. Same result - mid 40's. Tried without ATP - RHC39 till I ground off the decarb - then 44.
Tried brine - hot water - all it would dissolve (table salt) - floated an egg (an old test I'm told) - got RHC just under 65 - and a crack.
The crack may be because I didn't get the whole sample submerged -> uneven cooling.
Tried a piece of 1/8 1095 and quenched in the Quench K - just a hair under 65.
Is 1/4" thick 1095 just too darn thick to get under the nose in oil?
Suggestions welcome. By the way, this is all stock removal stuff.
Rob!
Rob!
