anyone use turco
Any of you knifemakers out there use turco for instead of toolwrap?? My question is what to do when it becomes real thick which often happens when you have it a while. It still works when it becomes thick but seems as if it will go on the blade too thick and thus wasting $100. a gallon turco. Any help will be appreciated. Thanks Mike
Mike, I just started using it. Mine came as thick as syrup. I thinned a small amount 50/50 with laquer thinner, put in plastic tubular container (drink mix container), and dipped. Came out what I think was fine.
Heat treated, bad results, it started popping off when air quenching ats-34. I don't trust my temp controller, it may have been too hot.
2nd attempt, I dipped, let dry, dipped again, for a nice looking coat light orange. Dropped temp of furnace a little, and this time I air quenched. They came out beautiful.
So you may want to not thin it 50/50, maybe less. I was advised that it works best if you let dry completely until the next day, not just let dry to the touch and into the oven.
Dan
