Why is the Swedish blanket so much better than the Italian?
Thanks,
Geoff
Probably wrong. When doing this style of sleeping there are alot of factors to take in. I worked as a backpacking guide for a long while and learned lots of tricks. Be sure to NEVER sleep directly on the ground. Even if you are using something as simple as old dry pine needles then always lay a bed down at least 4" thick. another technique is the coal bed style of sleeping. Dig out a shallow area 12-16" wide and as long as you are. Then transfer coals from your fire or burn some smaller wood and let it burn down to coals and then cover with a couple inches of dirt. This will keep you very toasty. Next is the upper area of insulation. Again this can be as simple as pine needles or you can also use ripstop tarp/space blanket or the like to help keep thermal loss from wind down.If done right a wool blanket can work down to the 20-30 degree range no problem.I must've been doing it wrong, because every time I tried the old mountain man style of camping, I froze my ass off (dipping into the high 30s at night).
I'd much rather use my down bag in those temps. It also squishes down to a loaf of bread size.
Price is another thing entirely.
I have not used a wool blanket, but I wear/use a wool pull over hooded shirt. I have slept in it when temps got chilly. Makes a great insulating layer. I LOVE the pullover.
Got it here
http://www.gfredasbell.com/gfa_wool_clothing.php
Got it here
That's a cool shirt. Which model is it?
It's the Wool Pullover w/ Hood. (not the Mackinaw) Timber Ghost Pattern.
