Anyone using their 0350 with the torsion bar taken out?
Yes. Mine is currently in but I change it up occasionally. It is just like any manual, and beautifully smooth action as well. The thumb studs are very easy to use without the torsion bar in it.
Probably should use an awl and punch it out slightly, then go easy with a tiny drill-bit / dremel. Just follow the arc of rotation and make a divot at the end.
it should function like a normal manual knife.
and mine has a detent in the closed position btw idk if they are all like that but mine is.
The 350 has a both a detent ball and the hole in the blade for it to keep it closed. Just disassemble, remove torsion bar and reassemble. No modifying necessary.
