You can get a long set of feeler guages and use that to set it accurately if you wanted, Mark. Otherwise, you could get close if you have a number drill set to use as guages, less close with a fractional set but still probably ok.
In order to get the best precision out of one of these types of markers, one has to be sure their stock is flat and the two sides parallel. If there is any warp in the steel, you will get curved lines and following them will grind a warp into your blade.
