wmk1228 said:Does anyone that has an Edgepro use it without water? Is this possible if you are doing mostly light to med sharpening and touch-ups? Also would the Spyderco 8x2 benchstones fit this rig ? ......William
I really like my belt sander for taking metal off fast, then finish with a sharpmaker, strops or an edge-pro.I would not get into belt sanders for sharpening, they work well for actually shaping an edge, but are way overkill for restoring a blunt edge unless you need major metal removal.
tim8557 said:Leatherbird,
Did you purchase the kit with the 3000 grit polishing tapes?
I find them to be amazingly effective. My belt sander has become my prefered sharpening tool.WadeF said:How effective is using a belt sander to put an edge on a knife? Isn't it generating a lot of heat at the very edge which could ruin the temper of the steel?
You sharpen on a belt sander with the edge trailing, as you would when using a strop. In fact, you can even get a leather belt for a belt sander, which you can then charge with your favorite stropping compound (I use .5 micron chromium oxide myself), which puts a beautiful finishing touch on an edge. Of course, you can use an uncharged belt too.WadeF said:Also when using a sander do you point the edge into the forward motion of the belt (like you would hone a knife on a stone) or away (like when you strop)?
