- Oct 2, 1998
I've been appendix carrying since the 80's, on and off the job. But my carry pistols do not have lights, nor dots, so YMMV. (I do have holsters equipped for both, I just don't carry that way.)
Can't tell you whether you will print or not as it is entirely a matter of physique, placement, and the clothing chosen. It is an important detail which too many folks who carry do not put enough thought and effort into, in my opinion. Sometimes being thin helps, other times not so much. You can check yourself in front of a mirror, or have a friend or family member take pix to demonstrate where you may be printing in some positions.
As for holsters, I can recommend those from JM Custom Kydex, Dark Star Gear and Tenicor, with the first two being my primary choices.
Pros and Cons:
Appendix allows for a quick draw...and also aids retention in that you can both better protect the gun in a tussle, should one occur, and also prevent someone from grabbing your gun from behind if you have a lapse of "situational awareness" while out and about.
The cons would be primarily resulting from a holster that does not fit or is not positioned properly in the inguinal crease / groove.
And of course, you must be able to safely re-holster without blowing your junk off...but that is easily mastered.
Also, be prepared to alter how you hug folks to avoid pressing the firearm against them. May or may not matter in various circumstances.
Pros and Cons:
