- Nov 29, 2005
Well, in the spirit of the other guy who posted about his figure-4-trap efforts with his kid this past weekend, I'll post about my unsuccessful efforts. And, for starters, I'll say that I'm very glad I did it on a weekend in my suburban home, after lunch, instead of out in the middle of nowhere, shivering from cold and hunger.
No pictures, unfortunately--I'm not set up for that--but you might have a look at some picture on the forums of forum-member Pict's masterful arapuca traps.
We have a mesquite tree in the back yard that has produced quite a number of fairly-uniform twigs of around pencil-thickness to twice as thick. I thought that this would be a great opportunity, and had a go at preparing the trap. Took two sticks, about 15 inches long each, and some paracord, maybe a little longer than 15 inches for each of the two strands. Tied the paracord near the ends of the two sticks, making a roughly-15-inch square, with two sides being sticks, and the other two sides being cord.
I held the sticks in my hands, parallel to each other, then rotated one of the sticks so that the cords now formed an X. This shortened the distance between the sticks significantly--and, since I remember forum-member Pict's arapuca-cages looking more square than rectangular, I started again from scratch, this time using more cord so that after I twisted the sticks and made the X, the length of the sticks was about the same as the distance between the two of them.
I then tried forcing in the additional sticks between the cord X and the two sticks. I found the mesquite twigs were kind of slippery, and were strongly inclined to move inward toward the center of the X. The cage always ended up coming apart after a few levels of sticks, probably because the twigs were too smooth, and, probably more, because I found it hard to maintain tension on the bottom levels of twigs while I added the higher layers. It occurred to me that it might have worked better if I'd used stakes driven into the ground to hold the shape of the bottom layers of sticks as I inserted the upper layers. Any suggestions, Pict? (Or anyone else?)
I'm fascinated by this trap concept--as are my kids--so I really do want to get it right. Incidentally, I recall being told that the really important/hard-to-learn things about an arapuca are what to bait it with, and where to set it. Any ideas on this?
Thanks, guys--it's great to have such a resource of experienced and resourceful outdoorsmen from whom to learn.
