The difference in edge-holding can be attributed to the BIG differences in the alloys. 440C contains twice the carbon as 420HC, and several points more of chromium as well. Also has a little bit of Molybdenum, which is a carbide former (420HC has no Molybdenum). The carbon, by itself, is the main determining factor in edge-holding (heat treat being the next most important). The chromium, when combining with the extra carbon, is going to create many more carbides in the steel (abrasion-resistance). So, the chemistry alone can account for both the greater edge-holding and the greater difficulty in sharpening, for 440C.
440C = 0.95 - 1.20% carbon, 16 - 18% chromium, 0.75% Molybdenum
420HC = 0.46 - 0.60% carbon, 13% chromium, 0% Molybdenum (none)
David, as always, I'm deeply indebted to you for your help and patience. The advice you've shared in the past on sharpening has really transformed my experience my Bucks in particular.
I'm struggling with integrating what you've written above with my understanding. To clarify, I'm really wanting to better understand how Buck's 440C and 420HC differ in terms of the modality of their wear. I don't have a microscope and not sure I would know what to look for if I did and I know I'm asking a lot for people to speculate about how my knives are dulling sight unseen.
My understanding of dulling is as opposites of the 3 primary qualities of steel as Joe Talmadge describes it in his "Steel FAQ". Crudely summarizing and recasting as dulling....
Wear Resistance - the ability to withstand (uniform) abrasion. The dulling takes the form of (uniform) loss of material and with that, a rounding of the cutting edge.
Strength - The ability to take a load without permanently deforming. The dulling takes the form of longitudinal waves or lateral curls along the cutting edge.
Toughness - the ability to take an impact without chipping or cracking. The dulling takes the form of (non-uniform) cracks and chips along the cutting edge.
Given this, here is what I'm finding confusing about what you've written. My understanding from Talmadge's FAQ is that carbides primarily help with wear resistance, not strength. Strength (as I under his FAQ) is primarily correlated to hardness (which depends, in large measure on the heat treatment) and is generally inversely proportional to toughness. It is also my understanding that the primary way knives dull are from chipping (lack of toughness) and folding (lack of strength) and not abrasion (lack of carbides). This assertion came from the Qknife FAQ but it/may be somewhat supported by Talmadges claim (in the FAQ) that in wood carving, the primary stress on the blade is lateral stress at the edge causing it to deform.
All of this to ask, what is causing my 440C blade to dull when wood carving?
Is it finally abrading, even though it is much more abrasion resistant than 420HC due to the increased carbides?
Or it is micro-chipping, possibly because it was hardened to a high Rc and sharpened to too thin of a edge for sustained carving?
Or is it folding as is most common with carving but resisting my lame attempts at stropping because my strop kung-fu isn't strong enough?
Sorry for the long post and sorry to be such a nudge on this.
