- Jun 29, 1999
Both work fine as safety measures, but neither can guarantee against abuse.
Wait... you guys use your knives?
It’s not a problem for me. I only need the lock to hold the blade upright. I learned long ago to cut and apply pressure only to the forward edge. For anything more involve than that I will use a fixed blade, or another more appropriate tool.I'm sorry, but this is another wild misconception with no basis in reality. Any force that's strong enough to bend steel or titanium isn't going to be stopped by your grip strength. And if your grip strength is the only thing holding that frame lock from slipping, then you have a defective frame lock.
Yum! Diabetes on a stick!yes Sir. you're the sugar cane farmer aint ya? I grow it in my back yard every year...love the stuff....
Any kind of lock is dangerous, friend. Fixed blades all the way.BOTH locks are super DANGEROUS! Just get a Buck 110. @rhino
Wow, I never knew there was a framelock Military, haha.Frame locks are considered stronger, but they shouldn't be. There is nothing inherent that makes them stronger.
I would put money the perception of frame locks being stronger comes from (1) most early frame locks being thicker titanium and (2) lots of cheap liner locks out there. On the first, people saw the thicker, metal handles (even if the cutout and geometry is what matters) and felt it to be true.
When Spyderco had the frame lock Military, lots of folks convinced themselves it was stronger than the thin liner version. Later Spyderco came out and said they were engineered to be the same strength.
A good question, I am glad you asked. I have always questioned this also. Enjoying the thread.Here's an unanswered question of mine. I get those sometimes and I usually leave them be.
I've gotten the impression over the years that frame locks are usually considered more robust than liner locks but I'm challenging that now. In my mind, I just can't get over this: both the liner lock and frame lock styles are limited in the stiffness of the lock bar or liner by the strength of the average user's thumb. Frame locks are thinned down to bend more easily, and liner locks are of a uniform thickness of the liner but narrow enough to not provide too much resistance to unlocking.
If failure occurs at the weakest part of the frame lock (rather than the big beefy part people see near the pivot) what makes them more inherently strong than a liner lock? A liner lock could be made that was very difficult to unlock if a very wide portion of the liner was dedicated to the lock, or the liner was very thick. My Rat 1 seems to have a stiffer liner lock than some frame locks I have.
Could it be that before the framelock became popular liner locks were the only thing around so people remember cheap liner locks they might have come across?
Any thoughts?
Every knife user should have to use a slip joint for a few years before they can get a locking knife. That way, they will learn how to properly use a knife and lock strength would become the non issue that it really is.
Very similar here. A SAK, no less. Closed on my index finger because i held it wrong, inadvertently.Lucky enough that my first misadventure with a knife only resulted in a few stitches. Left a lifetime impression on pre-teen me, though.
I believe so. Also, you are likely to feel the lock bar moving or shifting before it lets go.Wouldn’t a framelock be a bit less prone to fail just by the fact that you press the lock in as you hold on to it?
As for the liner/frame locks... the concern isn't about the strength. The concern is the design. They can fail if you have a tight grip. Combine that with a heavy job and you've got a potential disaster. Seems a lot of people are unaware of this (lack of experience).
Isn't the ability of the average human hand to easily bend steel or titanium a requirement for using these locks?I'm sorry, but this is another wild misconception with no basis in reality. Any force that's strong enough to bend steel or titanium isn't going to be stopped by your grip strength. And if your grip strength is the only thing holding that frame lock from slipping, then you have a defective frame lock.
