Are you willing to sacrifice the pivot? If so weld a cheater bar on and remove.I have a spinning pivot on a Kubey knife. It's odd I got it loose just enough for the blade to be off center and the pivot started spinning so I need to come up with a way to hold the pivot from spinning. Keep in mind I live in the Philippines and it is very hard to get stuff here. I'm paying $2 for a wiha bit to use my impact driver. I will be applying as much down force on that pivot to prevent cam out and will heat that pivot to what ever temp is best to break the locktite. I have a digital thermometer that can go up to 600 I don't want to mess up the heat treat on the d2. My torch is butane and comes to a very fine point at the end of the blue so that is where I would heat it I also have a heat deflector to lock it to the size of the pivot.
No im not I want to save this knife. I can't get any parts hereAre you willing to sacrifice the pivot? If so weld a cheater bar on and remove.
such as naphta,goof off,lighter fluid etc etc? adhesive remover?
