- Aug 27, 2004
Pitch angle. Nice phrase to describe the intersection of the blade and liner.
I have had liner locks fail, they were from large American manufacturers. And the pitch angle was certainly a lot steeper on them than others. Including the warranty replacement.
I'd add that the length of the active liner lock section has some affect on pitch angle because of the location of the virtual axis. They don't all exactly pivot at the end of the cutout, and don't really rotate there like a hinge, anyway. Short liner leafs seem to have steeper pitch angles, just because of the arc they travel.
Yeah I see a lot less problems in shorther less leveraged liner locks than I do the longer ones with a lot more leverage and the same thickness liners on them.
Pitch angle is just my own description that seems to help non knife people associate with the contact interface. To create a contact on a knife I'm making I set my table to the angle I need on my KMG belt grinder. I use a pitch angle locator to find that degree of angle. Then once I know its at 7 or 9 degrees I can then lay my blade flat on the table and using a 10" wheel make my contact so its slightly concave.
I would recommend testing the locks you use and looking over any frequently used locking folders often for debris, damage, blade play, and more on a regular basis. I do this each time I sharpen or touch up my own. Post number two in that tips and tricks link I gave above is a good simple test you can do yourself even sitting down.
STR
