Why do you use this piece of shit of steel is beyond me !
Aside from the warping of AEB-L, I have had good performance results from it at 62 or 63 in thin edge geometry. I think people are missing the point here though. The other steels I listed are curving as well. It’s not just my AEB-L and they are warping as I pull them from the kiln when foil wrapped.Why do you use this piece of shit of steel is beyond me !
I get what you guys are saying about the seam preventing proper contact with the plates. That isn’t my issue though. The issue I have is that in the 2 seconds between the kiln and plates, the blades are curving wildly. They are dead straight in the kiln and curve like a banana as soon as they come out of the kiln before they even make it to the plates. The plate quench seems to be fixing that for the most part, but if they never went between plates they would have a solid 1 inch curve or more. I think if I can stop this crazy curving as soon as the temp starts to drop, I would have very few issues with warps after the quench. Not sure if this makes sense.I think you've singled out your culprit. If your seams are thicker than your material, the plates can't make even contact along the length of the blade, so there's room for it to move.
I bet if you made your pouches so that the seams were outside the plates when you clamped, it would eliminate your problems.
There is a previous thread about welding foil pouches here with a link to a youtube video.Aaron Gough just shared this post on instagram, where he uses a transformer to weld the foil together instead of folding/crimping it. It seems promising, though I don't know if he's actually using this technique yet, I've only seen this one post about it. If it works it might be a nice way to keep the folds from interfering with a plate quench.
