Sheetrock is a proprietary name for USGs gypsum board. It is a gypsum panel sandwiched between two heavy paper face sheets. It is not stone, and not concrete.
Gypsum actually seems like kind of an interesting test medium for an EDC knife. It is definitely something I would try to avoid working on with my EDC knife, but also a good example of something I might want to trim quickly when another tool is not immediately available. It is a relatively soft, homogeneous material, but highly abrasive, and with relatively hard particles.
patrickcudd, when you say you were "cutting" the gyp board, are you talking about scoring it or actually slicing it?
This whole "hard use" thing is kind of vague. Much of the discussion often centers around people wanting to use knives for absurd purposes, or to compete with them on the basis of which knife can withstand more abuse. Of course it is desirable for a knife to be able to withstand abuse, but seems a little more important how the knife functions for its intended purpose.
In other words, I would be more concerned with a tool being too overbuilt to function well for common tasks that I would with it being too under-built to accomplish tasks that it shouldn't be used for in the first place.
A Sebenza is a relatively stout everyday pocket cutting tool. I look at it as more of an all-purpose tool than an emergency tool. It needs to be heavy enough to be sturdy, but not so heavy that it becomes impractical to use.
IMO, the SnG and XM-18 are a little more heavily built than the Sebenza. This makes them better suited for some emergency or abusive tasks, but less well suited for some of the more common tasks, like cutting fruit, cheese or cardboard. My general feeling is that a small fixed blade makes a better emergency tool than a folder. Compare a standard AD, a .17 GW or an SA to an AR or GB. The fixed blades are vastly superior in terms of their ability to withstand abuse. The only possible advantages of the folders are convenience and low profile.
The thing I really find interesting in all of this is how the various blade steel/heat treat/grind geometry combinations perform for reasonable cutting tasks. It does seem that there have been some issues with CRK's S30V chipping within the parameters of normal duty. My personal experience with this is more along the lines of very fine chipping, certainly nothing catastrophic. The wear modality of the blade is one where very small chips are removed, as opposed to one where the edge is bent or rolled, as is often the case with INFI or many tool steels. The immediate implication of this is that in order to be restored, the edge must have material removed, rather than simply being realigned with a steel.
My guess is that the reason more fine chipping is cited with CRK than with Strider products has more to do with grind geometry than heat treat. The CRK blades are just thinner, which also makes them cut better than the Striders. So there you have a basic trade-off: More emphasis on daily use, less on emergency abuse.
It seems like the advantage of S30V is that it has high corrosion resistance and yet is capable of taking and holding a pretty good edge. Its downsides are a lack of toughness and relative difficulty of re-sharpening. Both of those latter two ideas derive from the micro-chipping. So maybe Strider's approach to this is to leave the blade thicker behind the edge. Then you have all the corrosion resistance and a more robust package, but less cutting efficiency. Another approach would be to use a different steel. Presumably CRK would have used A2 on the Sebenza if they were primarily interested in toughness and cutting geometry, but at the expense of corrosion resistance. The decision to use S30V, and to grind it out thinner, is consistent with the idea of the folder as EDC, not EmergencyDC, which I generally agree with.
