- Apr 19, 2021
were the marks there when you initially stripped off the coating?
I'm betting they are machining marks left over from the CNC machining. Lots of manufactures PAINT their blades, cause it's cheaper than spending time on grinding/finishing the blade.... They say it's for "rust prevention".
-also.... look up Citra strip.... It's a nontoxic citrus paint stripper. It works and smells Nice.
Won't screw up a diamond stone..... :/
Welcome to the forum!
ahhhh....he thinks its bad heat treat. least said so in his review. it isnt bad heat treat its just level of finishing for a coated blade, like ya said.
One of my favorite blades.... 1311 looked WAY worse than his. I Wish mine looked like his. I'm still grinding/smoothing it out occasionally.... whenever I get a bug Up my rear.
To the OP.... Think of knife modding as part of the Fun.... and a learning experience.
you will learn new skills, maybe making knives of Your own someday.![]()
I think that is just machining marks. I wouldn't worry about it. I don't think you'd have much chance of warranty after taking the coating off.
I'd have to look again, it was prob just some tiny vibrations during the cycle. Maybe their jig isn't supporting the part as best it could....but since they Know that the coating will cover all those marks....it's No Big Deal.
Only you can decide.
* me personally, I really like that overall knife design, and it has been on my radar to someday own. Looks like a Very useful blade.
I'd buy a diamond file, from the Big River, and gently "Buff" the marks out.....
Stripping the blade can void the warranty, especially if you used abrasives instead of a chemical stripper. Coated production blades, like TOPS, Beckers, or KaBars, can have quite a bit of pattern under the coating. They are taken down smooth, but some grind lines are left in if they are going to get covered up anyway.
This is just a guess, but you took the coating off with a diamond stone and I don’t see any coating left. That means that you were running diamond over over the bare steel in some spots, because the coating doesn’t give way cleanly. Some of those marks are going to be yours, which makes a warranty claim unlikely to work. Those marks will come out, sanding it on a flat surface will take it out though. There are some great threads on sanding out scratches in the Maintenance sub forum, and automotive stores sell these convenient sandpaper packets that go from low number grit to high number grit wet sand.
I wouldn't be bothered by a few minor flaws in the surface of a user/camp knife.
Naturally we want our knives to come perfect from the factory, but we live in the real world. And if that knife did have a perfect surface underneath the coating it likely would have been more expensive.
I assume that any blade with a thick coating is going to have a bit of a "rough" surface underneath the coating.
TBH it's me had massive inner princes attack on this and now I had my lunch and beer and think yeah no point call any warranty after what i did to it already. May as well just enjoy what it is and look on the bright side.
With that said, for that price tag or all the quality stuff of make in USA etc, this is just a let down and not worthy any of it. Now on hindsight should just returned it at first sign of trouble: when i felt those dimples with my hands. Never more with tops, too military, too "murderous looking" and this quality issue.
Also to Crag the Brewer , it is a great camp kitchen knife no doubt, but if you already got diamond files, you need want to round off the gimping.
