WTT Armloc 2 HAndgun Safety System. I have had it for a few years and never used. Still new in the box. It's a great gase for any valuables.
http://s37.photobucket.com/albums/e52/DRFEEL/?action=view¤t=Case1.jpg
http://s37.photobucket.com/albums/e52/DRFEEL/?action=view¤t=Gun3.jpg
Interested in trading for knives or anything interesting you might have? Open to offers. Thanks for looking.
Here is the handgun safety system that provides security, instant access, nighttime operation, infinite mounting possibilities and a double locking system. Dupont Kevlar fibers are injected into thermoplastic resin. Kevlar of Dupont offers high tensile strength, low density, resistance to wear, corrosion, fatigue and flame; non-conductivity and damage tolerance. Incorporated into the case design is a handle for easy transportation. The Armloc Magnum makes it possible to legally carry a handgun from one point to another and from state to state. The Armloc Magnum meets all of the FAA requirements for Commercial Airliners. Features: elegant styling: sleek, round corners with a tough black finish that wont chip, scratch or dent; complies with new and existing state and federal regulations for keeping and transporting handguns; meets all FAA requirements for commercial airline travel; guaranteed against breakage; locks onto any bedframe or wall to prevent theft, yet is easily portable; quick release: special one-touch feature allows instant access when mounted to the bedframe; compact size (13 3/4 x 12 3/4 x 3 1/2 Outside Dim); weighs about 8 lbs; carries your handgun anywhere!
Mounting System Included: Integral steel shafted thumbscrews secure the case to custom mounting brackets. Steel flat mount brackets and exclusive bed frame brackets are finished in a black oxide.
Specifications:
Material - Dupont Kevlar fibers are injected into thermoplastic resin. Kevlar of Dupont offers high tensile strength, low density, resistance to wear, corrosion, fatigue and flame; non-conductivity and damage tolerance.
Components:
Hinges - Full length Steel Piano hinge Combination Lock - Three-digit tumbler in steel with a nickel finish. The lock offers the ability for setting and resetting a personal code. A steel backed housing plate encases the locking mechanism. Key Lock - Internal components are solid brass and resistant to corrosion. External - Nickel Plated Finish. Night-light - Nine-volt bulb and battery housed within the handle of the case lights up the combination lock exclusively for nighttime operation. Light switch is recessed into the back of the handle. Foam interior - Convoluted foam on upper surface provides secure placement of firearm with minimal space for shifting. Lower flat foam provides a resting place for firearm when case is open. Thumbscrews are recessed into the flat foam protecting the firearm from scratches.
Compact Size: - (13 3/4 x 12 3/4 x 3 1/2) yet fits most handguns and is completely portable.
Mounting System: Integral steel shafted thumbscrews secure the case to custom mounting brackets. Steel flat mount brackets and exclusive bed frame brackets are finished in a black oxide.
Transportability of the Armloc® Magnum Incorporated into the case design is a handle for easy transportation. The Armloc Magnum makes it possible to legally carry a handgun from one point to another and from state to state. The Armloc Magnum meets all of the FAA requirements for Commercial Airliners.
Features:
Elegant styling: Sleek, round corners with a tough black finish that wont chip, scratch or dent.
Complies with new and existing state and federal regulations for keeping and transporting handguns
Meets all FAA requirements for commercial airline travel
Guaranteed against breakage
Locks onto any bed frame or wall to prevent theft, yet is easily portable
Quick release: Special one-touch feature allows instant access when mounted to the bed frame
Compact size (13 3/4 x 12 3/4 x 3 1/2)
Weighs about 8 lbs
Carries your handgun anywhere!
Mounting System
The key to the Armloc lls versatile security system is two self-aligning alloy mounting brackets.
The Bed frame Mount installs easily to any standard bed frame without tools. Armloc II then locks firmly to the mount with two thumb screws inside the case.
The Universal Wall Mount can be installed virtually anywhere using conventional screws.
Both the Bed frame Mount and the Wall Mount are included with the Armloc II Handgun Safety System. Additional mounts are also available.
Specifications:
Components:
Features:
Weighs about 8 lbs
Mounting System
