Horsewright
- Oct 4, 2011
Use enoughand the glass wears out too. I replace mine about every six months or so. I've never had one break but I do have a lip and I use JB Weld.
Thanks Dave. My guess is I will never match your production throughout - I am lucky to get a couple hours in the shop every other day or so :-( ... so it will likely last a while... I’m developing a backlog of blades that need to be ground!Use enoughand the glass wears out too. I replace mine about every six months or so. I've never had one break but I do have a lip and I use JB Weld.
I got the glass glued up yesterday, and we are batting snow / freezing drizzle today ...maybe I will go hibernate in the shop and get some grinding done!
"Oooooo, there's some lovely filth down here!"reminds me of that scene from Monty Python and the Holy Grail where King Arthur stops to talk to the oppressed peasant slithering around in the mud.
That there is a five dollar word.socioeconomic
I have heard that ... presumably to help make up for irregularities in the underlying metal, but I killed the thing, so I know i am smooth within a couple mills ... also, tape can be “undone” with acetone. In this case (conscious decision), the shelf is narrow 1/8”), and i do not want to risk the thickness of the tape raising the glass too much above the shelf, and if need be to remove the glass ... as horsewright and others have said ... a blowtorch softens the job weld. Glass is not really expensive, so I am ok going that route.....
I've always suspected that Horsewright is actually a very cosmopolitan person. He is just trying to hide itThat there is a five dollar word.
Too late ..... already glued up and cured:Just make sure that when you apply the JB weld, you DO NOT CLAMP the glass. A little bit of painters tape shouldn't hurt anything if you're worried about it sliding out of place while it cures, but I've seen a few makers "over clamp" the glass, and that can potentially do a couple of things: Squeeze out your JB weld and reduce its holding strength; induce stress into the glass which will cause it to crack prematurely.
Stacy - when you do that I, for one, would be interested to see the resulting knife!!!!When you want to bond something forever, use the 3M VHB tape strips. The most handy size for us is an 8 pack of 2X6X.10" strips for $7:
3M VHB F9473PC ADHESIVE TRANSFER DOUBLE STICK TAPE ( 8 ) 2" X 6" STRIPS FR SHIP 50021200561462 | eBay
They put the granite façade on buildings with that stuff. It comes in a variety of thickness, from just a few thousandths (great for some knife scale tasks) to a foam core that is quite thick.
I have been meaning to make a nice knife with bolsters and fancy scales using no pins or bolts - just VHB tape. After allowing a few days to a week to cure, it sholud likely be as strong as one with pins. It will survive 200°F continuous and 300°F for a short time.
Cosmopolitan, heck no don’ even know how to make one. Couple fingers of whiskey over ice and some water, we’re good!
Looks good! Yeah, no reason not to use aluminum for this purpose .. I just don’t tend to keep aluminum in my shop because of potential fire hazard (though remote I admit). Aluminum must have gone must faster! You could probably even make the thing out of delrin, now that I think about it!I made a platen for a glass liner with integral bottom shelf similar to Cushing's from aluminum today. Instead of using JB weld, the glass is mounted to the aluminum with outdoor carpet tape. While I was machining the platen on the mini mill, I remembered this thread and it almost felt like I was cheating after reading all about Cushing's struggles milling hist platen from steel. The whole project was really quick, and the mill even tapped the 1/4-20 threads for the mounting bolts for me. The aluminum seems plenty sturdy to me, I ground a nakiri on the new platen and it went really well.
for most folks.the only advantage of steel is that it is easier
I keep a bunch of aluminum around and really like working with it. I seldom grind aluminum, though, and if I do, I clean up right after. I am not sure how much of an actual fire hazard this really is, but it can't hurt to be careful.Looks good! Yeah, no reason not to use aluminum for this purpose .. I just don’t tend to keep aluminum in my shop because of potential fire hazard (though remote I admit). Aluminum must have gone must faster! You could probably even make the thing out of delrin, now that I think about it!
For what it’s worth, my answer to changing platen s was just to buy a whole new arm.I keep a bunch of aluminum around and really like working with it. I seldom grind aluminum, though, and if I do, I clean up right after. I am not sure how much of an actual fire hazard this really is, but it can't hurt to be careful.
Delrin is probably strong enough, but it might be difficult to glue to. If I remember right, it can be glued with CA glue but not epoxy. Aluminum is probably cheaper anyway.
I have to modify the L-brackets on the new combo platen I recently ordered from Ameribrade. Changing between the glass and felt platen is a pain in the neck. The platen came with hex head bolts which were most inconvenient and guaranteed to end up in the water bucket. I changed those to Allen head, but having to undo them completely is still a pain. I think I am going to just slot the angle brackets so I can slide the platen in and out without having to remove the bolts.
