Cliff Stamp said:...smooth steels leave edges highly deformed and weak whereas ceramic rods will actually sharpen them and remove the weakened metal.
Cliff Stamp said:Yes, there is a huge difference, a steel works by cold working the edge, it deforms it and removes small amounts of metal by abrasion, it isn't a good thing. The edge is left weak and blunts rapidly. In contrast, a strop just acts similar to a stone of similar grit.
-Cliff
DGG said:When you see they guy steeling the big chef's knife near the roast beef table as I understand it he isn't sharpening the blade but realligning the existing edge. I'm sure there is some minor amount of abrasion ...
Mtn Hawk said:It never seemed logical that metal that is weak and thin enough to be rolled back or deformed in some way could simply be pushed back into place and last very long.
Are you saying that steeling with diamond or ceramic rods is basically not steeling at all but another form of sharpening? If so, could I just forget about the whole process of steeling and sharpen instead, such as on a Sharpmaker, or is there some benefit of steeling with a ceramic or diamond rod that I'm not aware of?
2. You advocate steeling, just not with a steel rod?
3. Do diamond rods perform the identical function as ceramic rods? Or is one better than the other?
huugh said:Cliff - have you ever seen a butcher in work?
Jeff Clark said:If the knife and the steel get cleaned occasionally they at least don't have a porous surface to retain bacteria. Other sharpening systems need to be kept cleaner to work well and to maintain even an illusion of sanitation.
Meatcutter said:... but surely you shouldn't have to resharpen the edge by removing metal each time you use the knife as you are doing with ceramic/diamond rods?.
