Thanks for the link to Verhoeven's work, it is like A grade porn to a sharpening nut. Haven't had time to have a good read of it yet but I did notice he used a Razor Edge steel for some of his tests. I have a straight steel made by Razor Edge and I wasn't reel impressed buy it's performance. At first it was way to coarse and would ruin an edge after a short time, I did give the steel a rub with some emery paper but still found it laking somewhat. The guide that was on the end of the steel, though good in theory, was way to steep of a angle for my liking. Might pull it out again one day and have more of a play with it. As for the other steel he used I have tried similar one and they were useless, so I don't know that I can make any concusions on he's findings on steeling, still it's good stuff thou.
I sharpen my knives on a Lansky guide that I have customised a bit. I removed the rear finger screw and drilled and tapped a 3/16 thread in its place then fitted it with a machine screw with a hex key head so I can get it nice and tight. I also replaced the alloy rods with 1/8 stainless rods as I found the alloy one supplied tended to bend easily. The reason I chose the Lansky over other systems is it is nice and compact for taking to work each day, and I can use it without the need for a table or workbench to work at. I keep my work knives very thin, the edge relief is set to the minimum for the task it has to perform, obviously a knife used for boning will have a thicker relief than one used for slicing.
I use a double bevel edge, the secondary bevel is cut with a diamond hone with the rod pushed all the way into the slot and in the 25deg mark on the guide. The primary edge face is cut firstly with the ceramic hone with the rod level with the bottom of the hone as per instructions and in the 25deg hole. Then I follow with a black Arkansas hone set the same as the ceramic.
I would love to experiment with different some different types of steel blades, problem is getting them made with food safe handles.
Anyone know what steels are use in makes of butcher knives like, Victorinox or F.Dick etc.
