To be perfectly honest, a good carbon steel should be able to flex like that and not break. If it does break, then the HT was obviously bad. I have done this many times with my SHBM's. The funny thing is that the first time you do it, before you pull your knife out, you are pretty sure you ruined the knife. The first time I did it, I was sure I had ruined my busse. When it came out it went back to true. I did it with a few other knives and they went back to true. Then one day, I did it with another knife and it took a set. It stayed bent, lol. I was shocked.
Yeah I know what you mean. The first couple of times this happened to me I though oh gawd, I've stuffed it. But alas, no such thing.
then panic mode trying to remove it before it i permanent lol, like taking out faster will make a difference. I am still impressed at how tough that wood is to bend a thick steel knife.
Just out of curiosity, ever tried a splitting maul? Wondering what that would do.
No, it isn't something you can take with you. I just have a lot of experience with that tool, so however it works gives an idea of how hard the wood is.
My initial thought is it's harder than anything I've ever run across. But then again, I've beat dried sweetgum with an 8# maul until I was worn out! And it burns about like balsa wood in a wood stove. This is obviously a different gum!!!
Thanks guys. It is interesting: it sounds like it splits like our gum, sort of. Difference being ours is fairly easy to split, if you split it as soon as it is cut. If you want until it is seasoned, it is near impossible to split. Even a small chunk will give you fits. But not so much because it is hard, but because the grain is all twisted up (kinda like your photos show). Really difficult. But again, burns like balsa or paper. Not much heat. You almost get more warmth from the splitting than the burning.
