I am a huge fan of hollow handles, and have used a Jereboam for five years now. Besides my Randall Model 12, it is by far the knife I have the most heavily used. I re-coated mine in a green Cerakoat after the finish wore off.
I am not a fan of this knife for several reasons:
-It seems very slim and heavy for the 8.9" blade size: It actually weights slightly more than the 10" Lile Mission below it (!), which gives you an idea of its density... It is also balanced only 1/4" into the blade to the Lile's 3/4".
-The chopping performance is compromised by the narrow blade: It chops less than half as well as the Lile Mission, and barely over half as well the Randall Model 12:
-The chopping performance is further compromised by the narrower handle radius between thumb and forefinger, near the guard: A traditional fully cylindrical handle is much better here because, without this reduced radius near the guard, the knife sinks backwards into the hand much less, and so transmits more of the weight of the arm into the chop: Note the superb performance of the Lile Mission here, despite the Randall Model 12 being 20 ounces to its 16.9(!):
Because of how the narrow blade combines with the low sabre grind, the Chris Reeves has a tendency to hit the sides of a deep V cut, and will then viciously glance outward: It requires a wider V cut or it can be dangerous... The thinning of the handle near the guard seems to worsen this bouncing tendency...
-The CR edge bevel base thickness is 0.040" on my Jereboam, growing worse near the tip: Angle per side was no better than 18 degrees or so, and around 25 on the front third, and maybe even 35 near the tip. The edge was re-ground to be sharper near the tip, but I still consider it barely adequate... The Lile Mission's edge was 0.028", the Randall Model 12 and my Model 18 being both 0.020": This makes both the Randalls and the Lile far better slicers, and also better choppers. To be fair another Lile, a Sly II that I have, had to be re-ground from an initial 0.040" to a more useable 0.020" (initial workmanship was poor on that one, with wavy uneven surfaces), but the flat grind made its blade easier to re-grind than the hollow grind of the CR.
-The CR tube walls are nearly 1/8" thick, and this is way too strong and heavy, resulting in a very narrow and deep compartment that is inefficient compared to other hollow handles. The large inner step created by the cap's hugely long threading also makes filling the compartment very inefficient, this cap "step" pushing the content deeper as you screw the cap shut: Most other hollow handles do not have these disadvantages, but admittedly the Andrew Clifford that I have has even less internal space... The Liles have the largest inner space, and the Model 18 has a larger diameter, if less depth. Diameter seems much more helpful than depth for storing items...
-The edge holding of the A-2 carbon steel seems average, though it does seem less rust prone than Randall's 0-1, whose edge seems to dull just sitting in the sheath a few months... Stainless is always superior for these kinds of knives.
-Good points: The Jereboam is straight and precisely ground (though the secondary grind lines are not symmetrical). The sheath is very good. The knurled grip is absolutely superior, even if the handle shape is less efficient for chopping than a true tube handle.
-Bad points: It feels very heavy for the offered blade width/length, very dull on the front third of the edge, despite a finely applied initial edge.
I'll put it this way: The knife feels like a lifeless chunk, but I can't really explain the feeling beyond that.
The extra strength offered by the one-piece concept, over separate tube hollow handles, is to me illusory...: It likely does not make the blade itself stronger under batoning, and the thick one-piece handle walls may in fact keep the vibrations into the blade, possibly making the blade more likely to snap... The handle cannot really be wrapped with useful cordage in the way it is done on other, thinner wall tube handles. Also, true tube handles are fatter where it matters, near the guard, for much more efficient chopping use.
One thing that affects many more recent hollow handles is an obsessive overbuilding of the handle connection, resulting in too small compartments and an unnecessarily high handle weight. The CR line falls along these lines, while the Liles are correctly done in my view...
For a much lower price than a Lile, one of the most practical of the breed that I know of is the Andrew Clifford Sly II: It does, unfortunately, need to have its 0.040" edge thinned to 0.020" (easy to do by most pros), and the saw is useless for a simple lack of teeth top front dipping(!)...
The sheath is really its strongest, and most amazing, selling point: It is extraordinarily well-made, better than any other leather sheath you will ever see...: The tight interlocking feature of the sheath with the guard means the blade is fully stabilized without rubbing inside the sheath...: This means that even a dirty and contaminated blade can be put back into the sheath and will have the space all around itself to not be scratched or damaged at all by foreign particles, a truly unique quality backed by leather that is out of this world in thickness and quality...
Unfortunately it suffers from the same current obsession with overbuilt handle strength... But the sheath alone is worth the price of admission:
The knurled ACK handle is another big plus, because unlike the Reeves, the handle it is intended to accept cord on the outside (I wrapped 14' of 425 lbs cord), and yet the handle does not lose functionality if you remove the cord. The sheath, handle and 9.5" blade design (minus saw) really represents to me the most the concept can offer, although the "Mission" out-chops it. Too bad the ACK edge is a little on the thick side initially... The Lile Mission is very surprising in performance (and, unlike most, the Lile sawback works very well), while the Randall Model 18 has the thinnest initial edge: Avoid the useless sawback and the Randall becomes an even better choice. However, even its excellent sheath can't compare to the ACK sheath...
Gaston
