aspiring LEO looking for the best Spyderco for duty
Yep, there's sure enough lots of LEOs carrying Police models, but how about the D'Allara (named after one of NYPD's 9/11 heros)? It's not as pointy as most, but beauty is in function, and this knife is all about the work!!!
IMO a Carbon Fiber Police model is hard to beat. It's lightweight and has a good overall blade design. I also feel that the knife should be carried on your weak side(non-gun side).In the event of a gun grab attempt,your weapon hand will(should) be busy on the gun keeping it holstered. Atleast you have a chance to utilize the knife if it is carried weak side.Regardless what you choose good luck and be safe!
Later,
RJT
I love my CF Police. The reason I chose Police over Military is the locking mechanism. My personal preference is for the lockback over the liner lock, I'm just more comfortable with it. Either way you won't go wrong.
As a LEO myself, Military for "normal" applications (front right, or pouch on belt), and Civilian as backup-weapon (left front pocket). S.P.O.T around neck, i wear the basic AUS6 SE because it will print less in front of your vest thru clothing. Is Civies i wear a Ronin around neck, Yojimbo right front pocket (blue handle is less treathening to general public). Don't go for the SS handles , scratch way fast. Should u be engaged in Deepcover Ops, where u can not wear anything that screams POLICE, i wear a SE Blue DoDo front right, and a SS cricket (black would be better) clipped inside the waistband small of back, so they might miss it when patted down. For formal wear i have the SS cricket clipped into my Formal Dress Uniform pants :D i can NOT go to work without wearing a Spyderco! :)
STAY SAFE
I'd say a Delica or an Endura, simply for the price and quality. You're not going to be too upset if it gets damaged or lost at the price either.
Step 1: Find out what your dept. considers "OK" Regulations and climate vary.
Step 2: Figure out what you want it to do - will this be primarily a tool, backup weapon, or a mix.
Step 3: Try to find a good brick-and-mortar store where you can try out a few models. Spyderco has lots of blades that are similar, but can feel very different - Police, Military, Endura, for example. Actually holding them will let you make a better choice than otherwise. If you narrow it down to a few models, a good store should be able to order them and let you experiment.
My personal opinions -
Backup:
Consider a small fixed blade. If you're in a situation bad enough when you can't use something else and can't regroup elsewhere, you don't need to be screwing with an opening mechanism (including autos) or a lock that might fail. Otherwise -
Military - good all-around popular performer. Easy to find in G10. Tip is thicker than police
Police - large blade in a small package.
Endura - workhorse, easily replaced, slightly smaller than Military/Police if you need to work around a length restriction
(ATR) - Step up in tip strength, price. Different handle shape, and Ti handle will cut weight
(Gunting) - useful if OK with your department, and you want to spend time learning the ramp. Several die-hard gunting fans on this forum are also LEOs
Never used a Civillian, so can't speak on it. The thin tip and inability to stab would make me nervous using this as a last-ditch option.
Benchmade has some good stuff that competes directly with these Spidies. I have an AFCK (which was originally derived from the Police, I believe) Axis lock is very easy to open and close. I think Spyderco G10 handles have more grip. Handle shape, with the finger choil, is a bit different and keeps your hand well back from the blade. Don't like the beveled hole on the Benchmade - it looks and feels more finished, but the Spydie hole gives better purchase for opening.
Tools - this is the direction I would personally go in. You'll use a knife more in this capacity, and a serrated model can still make pretty devastating slashes through nearly all clothing.
1. Assist - if the finger-groved handle is comfy, it's pretty hard to beat, since it was designed with you in mind.
2. D'Allara or Rescue - nearly identical function, buy the one that feels better. Ball bearing lock takes a bit of getting used to, and may be more difficult to operate in extreme conditions (particularly cold, or with gloves).
Good luck! Stay safe!
