a good old fashioned carbon steel blade.
Stainless is ok - if you want something that resists moisture.
But, if you want a sharp blade - with minimum effort going into keeping it that way - you just can't beat "rusty steel".
My years at deer camp say otherwise.
Seemed like the older vets I hunted with spent more time touching up their knives, and I wasn’t using anything overly modern.
I believe Ed Fowler would agree.I'm a carbon fan myself.
Also, I think heat treat is just as important, if not more important, than the type of steel used.
I'm not sure if it was because the blades were in need of touching up, or, if it was more the ritual of touching up that's responsible for thatMy years at deer camp say otherwise.
Count me in as part of the 1%... I'm content to leave my blades alone until they need some attention. That doesn't necessarily mean they're dull; but I'm guilty of that, sometimes, too.Really - if 99% of us fessed up to it - I'm sure a lot of us "touch up" our EDC blades on something (me personal choice is a Sharpmaker) even if we haven't used them and/or used the just for a cut or two.
This isn't correct. 1095 is still popular and some use it to create a hamon effect. It can easily be hardened above 60 HRC. You guys should look at the knifesteelnerds website to see properties and heat treat protocols for a variety of steels.I disagree. 1095 carbon steel is not very hard, (Rc 53?) though it is easy to sharpen. For the money, you can get an entry level stainless that is very nearly as easy to sharpen, harder AND stainless. (AUS8 @ Rc 57, for example)
Yes, there's a certain charm to carbon steel, but it's not anything related to edge retention or ease of sharpening. The charm is that it stains and doesn't always look surgically clean. The staining often makes it as smooth as a high-polish stainless, but without the fingerprinting.
One parallel I would draw that is more favorable to the old tech is cast iron cookware vs. aluminum non-stick: I just recently got a ceramic-coated skillet. The main advantage is how quickly it heats up and how little oil or fat it takes to cook with. Cleaning is actually harder: no soap is needed for cleaning cast iron, and abrasives can be used on the cast iron. (I use a stainless scrubby and a plastic scraper) Then, put it over the fire to dry it for next time. It also sears better.
