kbak - when you say that, you mean:
- using no protection @ all
- using PBC special
- foil ?
There seem to 2 different schools when it come to HT and finishing:
- some do 150 grit and it goes to HT
- some go all way up to 600, where it is nearly polished
Methink that 2nd group outsources HT to Bos - and with vacuum ovens, the blades
come back as shiny as they went in.
Both groups leave nuff meat to correct for warpage, if any and not to let cutting edge
itself to warp - which it sometimes does if it is too thin. Air-kool steels have excellent
dimensional stability when quenching and thusly don't (ever) warp.
Oil-quenching ones is an altogether different story - these will warp like SOBs of left too thin @ the edge. At least 60 thou is a must.
OK.
I use an Even Heat oven for heat treating as well as sometimes doing OA for edge quenching.
Mostly I use 5160. In the last three years, maybe 150-175 completed knives, I have had two blades warp, and they were W1, and about 10 inch blades.
Most of the time I grind to full finish with a nice 220 hand-finish running lengthwise.
Never heard of such a thing like .060. I might leave .020, and that is rare, maybe if I got lazy, which rarely happens.
Main reason I got to almost full finish, if you go to all the trouble of taking a knife all the way through hardening and tempering, why in God's name take that blade BACK to the grinder and start grinding away with the possibility of introducing heat right into that cutting edge? You can exceed tempering temp with a blade edge in a split second and RUIN everything you just accomplished.
From my experience, warpage more than likely comes from a blade NOT being ground to almost finish. Warpage is a cooling "difference" in geometry - for example, on a blade that is NOT ground to its full finished symmetry, you will get cooling variances on quench - one side cools faster/slower than the other side due to thickness differences and then warps.
Warpage is not an issue in my shop even when I grind to full finish. I think doing so actually eliminates warpage.
Do that, along with proper normalizing, spherodizing, etc. and "warp" shouldn't even be a word in your vocabulary.
I'm just trying to figure out, with all things being lined-up, proper temps, etc., what is the normal depth of de-carb in the average maker's shop when using non-atmospherically controlled equipment if temps and time are watched so as not to exceed extreme temps for long periods of time.
Proper procedures followed, bare naked steel, what is the depth of de-carb?
