- Feb 24, 2000
In stock removal, I have made hundreds of ATS-34 knives. Recently the steel supplier whom I trust has stopped handling ATS-34. Since CPM 154 CM is very close to ATS-34, I have begun to use it.
When I ground the blades profile, and drilled the holes, I didn't notice any difference. But when I went to taper the tangs I got a surprise. I was used to using Klingspor 36 grit Zircona belts, and could taper over twenty 1/8" thick ATS-34 blades.
When I went to taper the CPM 154, the Zircona didn't begin to cut. I went to a 3M 977 36 grit belt and it worked well, but I doubt I will be able to taper more than 15 tangs with one belt.
When I ground the bevels on ATS-34, I used a 60 grit Norton Hogger, and could do maybe 25 blades with one belt. With the CPM 154 steel, I have done ten and can maybe do five more.
When I ground the mill scale off the flats on ATS-34, I used a Klingspor 220 J flex belt, and could do five blades. On the CPM 154, the Klingspor 220 belt doesn't cut at all. I had to go to a 3M 977 in 120 grit.
I thought maybe the CPM 154 steel had not been annealed, but I checked on my Rockwell hardness tester, and the ATS and 154 steel tested the same.
I can use the CPM 154 steel, but am surprised at the difference in working it compared to ATS-34.
Anyone else notice this?
