jdm61
itinerant metal pounder
- Aug 12, 2005
When I said "brazing" I meant hard soldering with a MAPP torch and hard silver solder. Sorry for my misuse of the terminology.
As for threading, if the tang is not too hard, O wold just grind it rond and thread, but do it gently. The other way I do it is to slot a piece of all thread drill a hole and pin it to the thinned down tang to make a clevis. That makes lining up the buttcap a lot easier. You still get a physical connection and the epoxy firms everything up. You can even use a rod that is wider than your tang. Just install the guard first or blind the sides of the all thread rod a little flat.
