- Jan 2, 2009
I have a rasp blade that I want to put a brass guard on. The guard has a 1.24" x .1875" slot.
The plan is to enlarge the slot to fit the blade and slide it onto the handle portion up to the blade. This will be a full tang knife.
Question: what is a good method of attaching the guard to the blade? I was thinking silver solder but since I haven't done any silver soldering I'm hesitant to attempt it. I'm concerned about build up of solder. Will the solder flow well enough to fill any gap between the blade and the guard to hold it solidly while avoiding a build up which might cause problems when putting the handle on?
OR, if I put the handle on tight enough, will that be enough to secure the guard? I'm concerned about this as I won't be installing a pommel and/or peening (sp?) the tang.
Thanks
Thanks
