- Nov 27, 2013
So I'm doing my first skeletonized knife and I started thinking, should I use the same method(rouging surface area and using epoxy/pins) to affix the scales? There isn't as much surface area as I'm used to having and there a ton of voids/skeletonized area for the epoxy to squeeze into. Will that effect the strength of epoxy?
I'm thinking maybe I should use screws to affix the scales, similar to how ESEE does. The only problem is I'm not sure what I would need. It appears as though there's just two screws and a female piece inside that they screw into. Does anyone know the name of the "female piece" or that screw setup?
Should I just stick to using epoxy/pins as how I'm used to?
