autogateman
Rod Braud
- Jan 6, 2017
Hey Guys,
Ive taken a break from fixed blades and have been focusing on learning how to make slipjoints over the last couple months, and there is one thing I can not consistently get right. Im having problems with CA glue not firmly holding the SS liners to the scales. I can get them all glued up and it seems like any small amount of heat from sanding or just the impact from peening the pins makes them try to pop loose. All have been bolsterless so far. I have not had a single problem with G10 or micarta liners. Im roughing up the SS really well to give it something to bite to also. I tried the same epoxy as I use on my fixed blades and it did work better, but the CA glue is so much thinner it leaves a neater seam. Whats everyones method that yall find to work well for that?
Thanks in advance
Rod
Thanks in advance
Rod
