- Sep 22, 2003
Hey Y'all?
I have this blade I want to put stag scales on but I have never used any stag before, especially gnarly irregular stuff.
First is there a danger of stag tearing out when the bit goes thru it like wood?
If so what is the best bit/technique to avoid this??
Second, what is the best way to assure that the hole I drill thru the irregular stag is perpendicular to the tang? Do I want to use a little bubble level or something and sort of shim it up to make sure the bit is going straight down thru it????
Third since you want to not grind off the "bark" of the stag what is the best way to set pins in it? I was speculating possibly gluing both scales on and drilling the holes, then measuring and marking the depth of the holes with a wooden dowel or something?? and then cutting and polishing the ends of the pins and lanyard hole before inserting them??
Any tips greatly appreciated?:thumbup:
