conan11
- Jul 28, 2014
Himalayan Imports! https://www.bladeforums.com/forums/himalayan-imports.739/
Thank you, Andrew, for the explanation!I think that it helps in these situations to have a look at dated antique blades and see if there are trends.
I agree that straight handles saw an uptick in the second half of the 20th century. I think that part of this is just that handles got longer as user's hands got bigger- both through sales to westerners and also the Nepalese themselves becoming larger. If you were to measure the angle created between the bolster line and the flare of the rear buttcap these angles are often very similar it's just that on longer handles this occurs over a shorter distance so the radius of the handle curvature is a lot more intense. This can be seen on our blades with small vs large handles.
I think that it is also the influence of the mk5, of which historical examples had really quite straight handles. I think it can be said that a lot of the features of this blade (buttcap style, bevel style, blade shape) became almost the standard for khukuris for some period afterwards in the bulk export and souvenir markets.
I also like the ergonomics of the more strongly curved handles and think that Tora handles are quite comfy. However I think that some tora examples I've seen are so curved and hooked as to be ahistorical for the style they're going for. While there were certainly some handles that intensely curved it was far from as universal as it has seemed in tora's lineup at some points. A look at some of their BSI's compared to original examples sometimes shows a drastically different handle shape for example. I don't think this is necessarily a bad thing as I do believe that for the majority of customers these are more comfortable and locks the hand in nicely. Offering a consistently comfortable non custom traditional handle for westerners is a real challenge and I believe that some modifications should be welcomed. I think that the main thing such handles fix is to get the upper point of the buttcap tip nice and far away form the meat at the back of the palm- pressure at this point can be horrible especially with formed sheet metal buttcap styles as seen on the BSI for example. Alternative buttcap shaping and more generous handle sizing are other means of achieving this goal.
In terms of historical examples of longer handles the hanshee style are very long- to the point that some have speculated that they were intended to be gripped in front of the handle ring rather than using it as a subhilt with the rear portion being counterweight/offhand support. Some of these handles are quite intensely curved but some are really quite straight. Beyond this time I would be tempted to say that broader blades with more tip drop tended to see more curved handles but there are so many exceptions. It's very possible that this was a matter of user preference when getting a blade made. I think that metal handles often had a bit more curve than non metal handles. I kind of associate these blades with india but don't have much reason to make that association. Here's a very curved indian example with a metal handle that maybe helps with that connection.
Take care,
Andrew
