- Oct 2, 1998
I'm seeing a bunch of test posts, so I figured I'd help you guys out. Here's some basic instructions for you...
1. Click on the User CP button at top right.
2. Click on the Edit Options link at top center.
3. Scroll to the bottom of the screen. Click on the Change Avatar button at bottom right.
4. Click on the YES radio button. If you don't, your Avatar <b>will not upload!!!!!!!![/b]
5. Click on the browse button and find your Avatar image on your computer. I typically put them on my desktop for quick and easy uploads.
5.1. Make sure your Avatar is no larger than 120x120 pixels.
5.2. Make sure your Avatar is no larger than 10K in size.
6. Click on the submit modifications button. You will be returned to your user control panel.
7. Click on the Edit options link again.
If you can see your Avatar under that section, then you did things correctly. If not, then somehow you aren't following the instructions. Repeat steps 3-7 again.
http://www.bladeforums.com/forums/member.php?s=&action=editavatar
Here's a direct link to your profile's control panel > Avatar section
Kevin
Kevin
