Ok guys, after fixing up my Vic Fireman, I wanted to know what else could be done this way, and how well it would benefit the normal use of a belt knife.
So, I did almost the same thing as my fireman, except I didnt need to do any grinding. I just went right too the sander. The first knife I did was the USMC from Ka-bar then I went ahead and did the same to my Master-hunter. The ka-bar has what I would call a scandi grind and has the back swedge sharpened, then put a full convex on the Master-hunter and I have to say they work amazing. If any one is really interested I can go back out and show the full technique, but for now here are some shots of the knives.
Different angle.
Now this is shavings from the swedge of the USMC, its very sharp.
And then them all together.
What im most amazed at here is that level of sharpness I got from 220Grit paper on a Drill press, Im not gonna use anything else. I havent even went over the finishing stages of the edge( the fine work you know).
And for you non believers, or the guys who just wanna see the masterhunter in action, I made a video of the knife making thin, and curly enough shavings to light from just the steel, no tinder. that will be up in a few minutes.
Someone said to along time ago If I could get my knife to do what a A1 from fallkniven did (lit shavings rite from the steel) I would be set, well now I am.:thumbup:
Different angle.
