This was a little project I did, up above our place. It was a pretty big Ponderosa pine, dead a few years or so.
Pretty soft on the outside, bark falling off, Heavy lean downhill, toward the road. A slight lean sidehill in the direction I want it to fall.
This Is where I want it, parallel the road, uphill of that bigger fir in the back. Thereskind of a hole in the sky there you can see. I'm falling it off its main lean by doing this,but not against it.
Simple tools. A broken Disston 2 man saw I converted to single 42", 3 lb kelly perfect axe on a 30" octagon handle, wedges, saw lube.
Chop off some bark and start sawing for theface.
This is a pretty big tree, so we do that a while, until it's about 1/3 deep.
Then it's time to chop it out.
Chopping it doesn't have to take all that long, but there's a process to follow if you want tomake it efficient.
Start with a nice little bite that'll pop loose in a swing or two and clean that up all the way across. Then take another layer. Repeat, chasing it all the way in until it's a clean face.
If you get greedy, it takes too many hits to loosen the chips. Too shallow and you're nibbling. Either way your not getting your money's worth!
Continued.....
Continued.....
