Square_peg
- Feb 1, 2012
I wish we had had digital cameras back in the days when I was building custom homes.
What specific lengths do you recommend?
Why did you quit? We've got rich building.I wish we had had digital cameras back in the days when I was building custom homes.
Love your work Quinton!
I'm going from memory & looking at a tape measure, and am pretty sure I have the 200mm flat fine cut, and the 110mm flat extreme-fine cut.
http://www.woodcraft.com/product/150562/iwasaki-file-200mm-flat-fine-cut.aspx
http://www.woodcraft.com/product/150566/iwasaki-file-110mm-flat-extremefine-cut.aspx
The curves on an axe handle are gentle enough that these flat files still work fine. I made the mistake of getting a half-round medium cut first (I didn't realize they only have teeth on the curved side), and it's way too aggressive. They ain't cheap, but saved me hours of work and frustration on the first job I tried with 'em.
Press hard with the big one, and it will chew off wood so fast that a draw knife becomes optional. It's about like using a super coarse farrier's rasp, except that it actually cuts the wood so ya don't have to worry about tear-out, takes much less effort, and you have the option of using less pressure so you can refine the shape without leaving a lot of gouges to clean up. The little one is for final shaping & cleaning up what's left from the bigger file, and can get into tighter curves (like at the butt and neck) easier. Use light pressure, and it'll leave a finish that barely even needs sanding.
We have a local Woodcraft about 45 minutes away. I'm going to check these out. My old rasps won't last forever, and these sound as if they deserve a look see!
You will like. We tested several rasps at a gathering of muzzleloader builders and the iwasaki was everyone's favorite in speed and finish. My farriers rasp is fast, but leaves the things a touch rough.
Thanks for the endorsement, BG. I am very intrigued, and have been since the possum mentioned them last year.
No problem. I forgot to add that I liked your library work! Glad I didn't post any pictures that I'm proud of, eg chicken coop, plank fence, run-in sheds...![]()
When it comes to tools for shaping hard wood that likes to tear out, I'll keep singing the praises of my Iwasaki carving files. Oh my gawd, they're so awesome.Wish I'd discovered them 20 years ago. Buy a big 'un in fine cut and the little one in extreme-fine cut (which is actually still more aggressive than most regular rasps), and you can thank me later.
Sharpening it so there is a uniform edge showing is going to be a real challenge. I'm looking forward to hear how you make out with this.
Peg-the trick for me to a concave spokeshave is simple, dont use them.
Quinton- I have also found them useless on hickory.
