Seems I've been bitten by the axe bug.
This is what I'm up to - maybe the brains trust can put me right where I'm charging in where angels (or experts) might not.
The first project was to reshape the bit of my Australian-made Kelly Dandenong 4.5 pounder. That was way off Hook's ideal of 15 degrees included angle a half inch behind the edge. I roughed it out with an angle grinder (avoiding blueing) and then worked it on an upright stationary sander down to a medium grit. Next I'll improve the appearance by smoothing out the facets and making a 30 degree micro-bevel with a 2" rotary sander and ceramic discs as used by woodturners.
This has proved a lot of work. Must be pretty good steel. It's going to come in at a bit under 20 degrees in the event.
This axe still has the original handle but it's poorly shaped so I sourced a replacement from House Handles. (I've had this since new, for several decades. Looks like we're turning into antiques together. Must say it's heavy in use and the balance isn't the best.)
The second project is to rehab the head and hang a Collins Homestead double-bit. The profile is much closer to Hook's ideal than the Kelly's and it won't take long on a portable belt sander mounted in a cradle. I gather that it pays not to thin down the heel and toe too much, for strength reasons.
The belts for this sander don't run finer than #120 that I can see so maybe the rotary sander will do to polish out the scratch marks.
There's a handle for it, again from House. Shaping the top for the eye will be a first for me and is going to be interesting. I need to avoid ending up skewing it. Any tips welcome!
Kelly on Sorby ProEdge https://www.flickr.com/photos/30283858@N07/
Collins head on belt sander https://www.flickr.com/photos/30283858@N07/
I set the grind angle on the cradled belt sander by trial and error, checking it with the small angle setter in the pic. If anyone is interested in doing that by numbers, a one part rise in a six part run will produce a smidgen under 10 degrees on one bevel.
Project 3 will be to rehab a Kelly True Temper Flint Edge double bit. There will be a lot more grinding with that to remove a good sized nick.
Kelly on Sorby ProEdge https://www.flickr.com/photos/30283858@N07/.
Collins head on belt sander https://www.flickr.com/photos/30283858@N07/I set the grind angle on the cradled belt sander by trial and error, checking it with the small angle setter in the pic. If anyone is interested in doing that by numbers, a one part rise in a six part run will produce a smidgen under 10 degrees on one bevel.
