- May 6, 2004
i have read this thread with much intrest
real world- power plant electrician use
metal straps on metal conduit.. i would wedge the point in and hook the chamfer under one side and push down on the handle to cut the other side with the edge of the knife..
NOT an approved use i know but it worked...
i had the lock on a buck fail once doing this.. and seen many other lock backs fail as well as liner locks.. also the release on most can accdently be engaged partly doing this and the blade will close !
i still hook the back side of a blade under heavy duity tie tie's and push down on the back of the handle to cut through with out cutting what ever the tie tie is holding.
many say the spine wack is not a valid test ... as a shock test i dont know...
however i maintain a lock should be able to with stand closeing with a steady heavy pressuer to close the blade agenst the lock ...
sudden failure of a lock is never a good thing and i feel there should be a test to determand at what pressure a lock will fail to hold open the blade..
as a former hard use owner i am more concerned with the lock failing then being so easy to open..
this because that carrying a fixed blade was/is not an option at work or most places..
