I have to disagree. The Compression lock is actually sort of similar to the Tri-Ad in the way it uses a pin to wedge the blade tang. I don't know if the Axis is as strong, who knows which is more durable, but I would definitely put my money on the Compression lock. It seems to be a lot stronger and less likely to fail and I also think it's more durable/less likely to develop play. I'd be surprised if the Axis was as strong as the Compression but I definitely trust the Compression lock more. On the other hand, the Axis lock is probably stronger than I've always thought it to be. The Compression lock is definitely one of the best designs out there, though. I have a lot of faith in it, especially after seeing the video by Neptune Knives. He abuses so many knives and almost always gets them to fail pretty easily, but the PM2 stood up very well I thought. Even after he got it to fail once, it kept working and continued to resist failing pretty well IIRC. It didn't just fail easily once damaged. It seemed to be harder to fail the second time.
Which would you guys rather have on your edc? I think the axis lock is easier to use but the compression lock doesn't have the omega spring that could fail...
What do you think?
Edit: can't seem to find out how to add a poll...
The compression lock is a very nice lock , but it's not even close to the strength and durability of the AXIS or the Tri-Ad
The AXIS lock is 100% usable functional and solid even with one omega spring
The correct answer is that if you manage to break either then you've done something really wrong.
Well I like the compression lock just because it is a lot simpler than the AXIS lock and there are less things to go wrong with it. The AXIS lock you can do an easier one handed opening if you pull the lock back and let the blade come out just by its own weight. I also like how with both though you fingers are out of the way of the blade when it closes. They both have their pros and cons but when it comes down to it I personally rather have a compression lock.
The question in the OP is now moot, as now it is a "Benchmade vs. Spyderco" thread:grumpy:.
You are basing this pronouncement on what objective data? but I am VERY skeptical of your opinion of the relative strength of the two.
I based what I said on facts , facts I gathered from knives which I destroyed during extensive lock testing , and I destroyed quite a few of them .
Some people on this forum love to test super steels and their edge retentions like maniacs , I'm the exact opposite , I don't care about super steels and extreme edge retentions , but I love testing locks to their limits .
I have a series of different test I'm doing on each lock , and in the case of the Compression lock , it failed miserably comparing to the AXIS and Tri-ad .
Compression lock is not even close to the AXIS or the Tri-Ad , in fact , during shock tests the Compression Lock failed even more then some of the liner and frame locks I tested .
The AXIS lock and the Tri-Ad lock on the other hand are extremely strong locks , in fact they are so strong that it is almost impossible to make these two locks fail as the blades and pivots will almost always fail first , and needless to say they passed the shock tests easily .
I really don't care that you or other Spyderco koolaid drinkers in this thread are "VERY skeptical", I'm just calling it like it is .
