I'm sold on the Axis lock. I've not had any blade play issues with any of the ones I've had, and I have polished the lock bar on some as mentioned above.
Belly, when you are sitting around watching tv or something, just open and close the knife as you are watching. DO NOT check it every ten or twenty openings. People on a diet that weigh everyday get frustrated when they see no results and quit. Same thing can happen here. The break in wear is not going to happen real quickly, unless you can open and shut the knife a thousand or so times in a night.
As the lock bar is pushed forward, it slides between the top of the oval frame cutout, and the ramp of the blade tang. As it wears the lockup should become tighter as it wedges more firmly in place. Just remember that these are hardened steel parts that probably rank between 48 to 54 on the Rockwell, and I did sorta pull those numbers from my azz, just remembered reading about hardened steel parts falling within this range. Anyway, those hardened parts do take a little time to wear in.
IF both springs were to fail you, the lock can still be pushed forward into the slot and could be held there by putting a little stick in behind it. But unless you are just one unlucky guy, I don't think both springs will go at once, if at all. I've read many posts about omega spring breakage, and it does occur, but it is what you don't read that you should look at, and that is how peoples Axis Locks don't have failing omega springs. For every one breakage you read about 10 that haven't broken, ok, another number out my azz, but it is close if actually not higher.
But all this aside, I hope your Adamas does begin to lock up to your satisfaction, and there is no play in the blade when it does. This is the first BM that I will have three of, one of each variation.
