- Mar 8, 2008
When putting the pivot pin back in just use a paper clip and a "stirring" action inside the hole to center the washers. Easy-peasy.
When putting the pivot pin back in just use a paper clip and a "stirring" action inside the hole to center the washers. Easy-peasy.![]()
I've found that using a q-tip stem to hold the Axis lock bar back makes it much easier get everything put back together. Some people use a toothpick, which also works. I prefer the q-tip because it's a bit thicker and gets the Axis lock further out of the way.
I've done the same with a spare screwdriver or torx bit.
I tried that with a torx driver I have, and it didn't really help at all. I must have done it wring, because all it did was act like a small pivot bolt. Didn't seem to serve any purpose.
Which knife is in question.
LoL. That sucks . It usually takes me about 5 minutes to do a Griptilian if I dont look at what I am doing.
Practice makes perfect. Next time you will be a pro.
