- Dec 22, 2006
After sellin' and swappin' a bunch of gear around, I decided to ummm celebrate by gettin' a new flashlight. I've gotten tired of some of the micro LED lights like the Photons, so I thought I would get another Fenix. I have a P1 and it works great, but it does on CR123's which can be spendy and it is short but fat. I cooked up a PSK in a Nite Ize pock-it and I wanted something slimmer-- a little taller was okay. So I got on the Fenix-Store web site and found an EO for $20. It runs on one AAA battery and has a simple twist-on switch.
It showed up today and I was blown away by the small size and light weight. It's *perfect.* Seeing that a Photon can run $16, this is a no-brainer for me. And it takes a screwdriver and an act of Congress to change the battery on the Photon too. I can swap one out on the Fenix in the dark, without tools.
Wow-- I need to get Normark to make a holder for my F1 sheath-- firesteel in one, the light in the other {{{{{{{{shudder}}}}}}}}
Here's a shot with it on my PSK lanyard. Note the Scout-sized firesteel next to it:
Here are the factory specs:
Features:
* Uses Nichia LED with a life of 100,000 hours
* Constant Current regulation
* Constant brightness: 5.5 Lumens
* Uses one 1.5V AAA battery (not included), inexpensive and widely available
* 20-hour working time ( 11-hour sun mode plus 9-hour moon mode)
* 6.75cm (L) x 1.2cm (D)
* Made of aircraft grade aluminum
* Hard anodized finish, highly durable
* 9-gram weight (excluding batteries)
* Waterproof
* Twist switch
* Capable of standing up securely on a flat surface to serve as a candle
* Included Accessories: Spare O-rings
* Battery not included
* Includes a split ring and a spare o-ring
Features:
* Waterproof
* Twist switch
