- Nov 7, 2004
Post expired.
Pocket rocket is good - Soto stove is smaller and better, but costs about $20 more. Soto stove will empty an entire cannister while the rocket will not - has to do with a regulator thing in the guts of the Soto that keeps the vacuum all the way to the end.
I personally find the Pocket Rocket to be fast and fairly light, the Alky stoves to be slow and very light, and the liquid fuel stoves to be heavy and robust.
Do you own the Soto? If so what is the coldest temp and altitude that it worked?
I'm thinking about getting it or the Brunton Vesta. I have the Brunton Raptor and it works like the Pocket Rocket.
This is how I used to think...Zen pressurized top burner: 3minutes 10seconds (I couldn't believe it! This has to be the fastest alcohol stove I have ever seen! RIP Pocket Rocket...) http://zenstoves.net/BasicPressureBurner.htm
I have had a pocket rocket ever since they first came out. They work great. I also use a JetBoil, which is even simpler to use since it is all contained in one unit. I have had good luck with a Trangia alcohol stove as well as a soda can alcohol stove. Snow Peak makes a great stove that is the equivelent to the Pocket Rocket. Fits in their Ti cup.
The next stove I want to get is the Bush Buddy. That seems like a great stove and you don't have to haul fuel around with you.
Anyone use a Bush Buddy?
I'd probably be more favorably-inclined to the cannister fed stoves if the canisters were refillable.
How hard could it be?I'd probably be more favorably-inclined to the cannister fed stoves if the canisters were refillable.
