- Mar 8, 2013
i am new to knife making and wanted to post my results from heat treating. i made a small forge with fire brick. i use charcoal for my heat source, a 1inch steel pipe for the air inlet at the bottom. i use a blow dryer for the forced air. i recently heat treated 2 knives that i made out of O1 steel. 1/8" thick and OAL blade lenghts of 7 and 8 inches. one is a skinning knife and the other is a boning knife. the blades are 1 1/4" and 1 3/8" wide. quenching is canola oil that i warmed to 140 deg. f. i heated my forge for about 15 min. then put the blades in, blade down, and soaked for 15 min. they were non magnetic after about 4 min. i quenched in my canola oil, let them cool off enough to handle with plain leather gloves, then put them in my oven that was already preheated to 440 deg. i left them in there for 1 1/2 hours, took them out, let cool to room temp. and repeated the process.
i just had a labatory that i have acess to, do the rockwell hardness test. they were tested in a coulple of areas on the blade. they tested at 58.5.
i was wondering if i tempered at 400, would that give me a little higher rockwell number?
