Badger Attack TAC - more questions.
Thanks rbmcmjr. That diagram is great. Still looking to know difficulty of grinding and pros and cons related to each.
I understand the diff between saber and flat. What is hollow? (This is even though I have an SK :-)
Also, which is the most difficult to grind and what is the relative pro/cos of saber, vs flat vs hollow?
Thanks (I realize this has probably been discussed ad nauseum somewhere on this forum, but figured I'd ask since this thread is up).
some basic pro's and cons -
convex - strength. if you have a full convex with a 1/4" spine that terminates at 1.4mm thickness directly behind the edge vs. a full flat 1/4" spine that terminates at 1.4mm thickness directly behind the edge - the convex will simply have more metal due to the outward curve. Convex edges can also lower the chance of a blade binding (getting stuck in) wood because the wood is exerting force over a single line of metal on the curve, rather then the entire surface of the blade.
saber - depends on the heigth, but basically trying to mix strength and cutting performance without a convex edge. That same blade with a 1/4" spine that terminates at 1.4mm thickness directly behind the edge with a half heigth saber grind - I dont know wich will have more metal. Depends on how much of a convex it is, if its a wide curve, they could have the same amount of metal, just redistributed, if its a very shallow curve, then the half heigth saber could have way more metal making it much stronger. Generally, I look at half heigth sabers as useful for 3 things (and only 3 things) - strength in a prybar knife, maintaining weight for chopping applications (rather then increasing the spine thickness), or maintaining strength in a thin blade (such as the 1/8" thick NARK). It does put a corner where the media rubs against as you cut, and you do have to shove your material apart within the distance from the edge to the half way point in the blade. on certain designs like the older public defender that was very noticable, since you went from 0 to 3/16" thick in about 3/4".
High saber - It's stronger then full flat. you get good cutting performance out of it, but still maintain an area of full spine thickness. addding that little bit of thickness at the upper portion of the blade can add weight for chopping ability without lowering its cutting performance noticably. it's also easthetically pleasing :D
Full flat - Good cutting performance. It can be a little bindy depending on other elements, such as blade heigth, coating, and what the media being cut is like (hard vs. soft wood, fresh or seasoned). When your spine is thick enough (1/4, 5/16", 3/8"), a full flat may be preferable to saber or convex to keep the weight down while maintaining the strength of the thick spine. It can also be used to help keep the blade balance neutral, since a full tang handle will be at full thickness, leaving a big ol' block of steel at the handle, pulling the center of balance towards the hand. An example being the HOGFBMLE with magnum handles. to me its almost completely neutral, not really giving away its actual weight. If you made it into a 3/4" heigth saber (wich I would LOVE!), the 3/8" thickness at the top of the blade would help to add overal weight, as well as pull the weight forward making it more of a chopping balance, without hindering its cutting ability too much. The HOGFBMLE benefits from having less metal directly behind its edge then almost any other busse combat knife out there (except maybe the sk, aba, and some of the zero ground overuns and customs). If your willing to keep the metal behind the edge thin, you can have some pretty gnarly thick blade grinds and still have it be good at chopping and cutting tasks as long as its not on a bindy media that would hang up on the thick blade like hard plastics.
Hollow - cutting performance. Will bind readily in wood. You decrease the initial distance that you have to push the material apart when cutting it, allowing for a smoother transition as the blade pushes through it. This does not mean that the thickness behind the edge will be any less, as that is determined by the knife maker, it merely changes how the knife passes through the media. It is a very bindy grind, wood will clamp down on the spine and not want to let go. Busse combat pretty much never uses this, except on spines, tiny knives like the sk, and on specialty situations like the war boar. essentially, on very short grinds where a full flat would hinder cutting performance greatly due to the short distance required for any cutting action. hollow grinds are the weakest of all shown here becuase they have less metal then the rest. It's a better grind for shallow primaries and smaller knives that wont have to deal with the heavy stresses of a chopper or a prybar.
The difference between high saber, full flat, and convex get a lot of controversy as to wether one actually increases cutting performance (or any specific aspect thereof) significantly. Personally, as long as the grind is high, the metal behind the edge reletively thin, I generally look for overal thickness, generaly weight, and balance. I want my choppers thick and very blade heavy, my machete's thin and neutral, my prybars thick and slightly blade heavy, and my slicers extremely thin and neutral.
Thanks for taking the time LVC. Very thorough. Agree with the aesthetics of the saber. For example, my green EU handled Mojo has a sabre grind and the Muddy Mojo is a flat. The sabre grind does look cool.
That being said, I wonder which of the three Flat, Sabre, Hollow are hardest to produce. Would also be good to know in terms of judging a knife's value (i.e. which is harder to produce).
lol.... Heres a cunnundrum (sp?), Full flat vs. hollow - same thickness, same amount of metal directly behind the edge, wich feels easier to cut with?
Lets make this hypothetical unique and a little more extreme to aid in justifying answers without having to add "but you wont notice the difference" because of the slim difference in thickness's
You have a full flat knife that has a 10" blade, 3" tall, and 1/2" thick. You have a second blade that has a full hollow grind thats very deep, but maintains the same basic profile and thickness. You are cutting denim that has been sew togheter, 30 layers thick. the block of denim is 5" thick, but not sewn so its packed like a brick, it can still be readily bent and moved around.
Wich will feel easier to cut with? (given that its going to be a pain either way). With the full flat, your pushing apart the material at an even pace from edge to spine without any major corners or edges. With the full deep hollow, your pushing it apart slower for the first half, but then trying to push it apart faster for the last half - and your have a literal corner where the 2 sides of the cut material are rubbing against.
Will the hollow grind really offer an advantage? or is it just for shallow cuts where your not having to push the blade all the way through the media? Is it only for media thats softer and does not exert heavy pressure against he blade as its being cut?
I think that the utility of the blade and the number produced effect the monetrary value of the blade the most with busse. SFNO's are ultra rare not because they produced 10 of them, instead they're rare becuase so dang usefull that everyone wants one and isn't willing to give them up. Where as the custom handled active duties and the other recent variants are rare and expensive simply because there was only 2 or 3 of each variation made.
If you mean personal value, as in an appreciation for craftsmanship, I'd say the ak and the sk were probably giant pains in the butt to make :D
I think that everything regarding blade grinds has gotten WORLDS easier now with the introduction of cnc beveling at busse combat. By being able to put the initial bevel in by a computer operated machine, you take a lot of the difficulty of hand grinding out of the equation. I'm not sure if the deep dish hollow spine grinds are done by cnc or not, I would assume that the band cutter style found on the force one and the nark are, but I could be wrong.
In hand grinding, Id say that full and full convex are the easiest, because you dont have to worry about keeping your grind line straight at the top. The high saber and the saber hollow would probably difficult, and the deep dish shallow heigth hollow's are probably a pain, especially on tiny little knives like the sk.
Thanks again. Yeah, I realize the supply vs demand factor plays the biggest role. I guess I am interested more in the areas that require the 'most craftsmanship'. For example, the satins requiring much more individual attention than the coated ones; the natural material handles probably much harder to deal with than micarta and G10; serrations taking more effort, etc.
Add to this the drunkness factor :D
Last Visible Canary: Do you use "full flat" to mean a full flat primary grind, plus a single secondary bevel for the edge? If you add a so-called "micro bevel" to that secondary bevel don't you really have a saber grind?
I'm not trying to argue, but I'm a details kind of guy and I don't understand the difference just yet. Thanks!
Everything I've said is in regard to the primary grind, completely disregarding what you do with the cutting edge itself. The cutting edge can alwasy be modified to be V, convex, assymetrical or whatever, but the primary grind, the spine thickness, and the amount of metal directly behind the edge require a change in the overall geometry of the knife.
To me, the cutting edge generally wont extend past 1/4" from the cutting edge itself, it is the portion that you shave off/sand down when you sharpen your knife. The primary grind is unnaffected by genneral sharpening, unless its a puuko style or a full convex satin finished and your literally grinding the entire primary grind down in order to sharpen it. In cases such as that, I generally add the descriptor "full convex grind w/ zero edge"
As far as micro bevels at the cutting edge, I consider that to part of the cutting edge bevel in general, and not something that would effect the overal grind geometries.
attachment.php
some fun with illustrator. theres some even wackier grinds that are fun to play with, like tin chirra (3 fullers making up an overal geometry that resembles a the full flat/saber) and completely assymetrical primary geometries, like full flat on one side, and hollow/low saber on the other.
the center shows the difference that acute or obtuse convex grinds can have, even without effecting spine thickness or edge thickness. The one I didn't include is when you split the difference, where the convex has extra material at the top and bottom of the saber, but less at the point between the full spine thickness, and the flat section of the saber grind. When you split the difference, you get into that grey area of wether its stronger, or has better cutting performance. The difference in hand is reletively negligable, unless your cutting something like hard plastic where the curve vs. sharp line of the saber can make a difference, or cutting wood that binds excessively. It's not really possible to combine the difference of a full flat and a full convex without either thinning the spine a little, or making the blade less tall.
the lower left shows your average khukuri grind, where the entire blade geometry slopes down towards the edge, but from a distance it looks like a very low saber grind. the red = full flat, black = khukuri grind, blue = saber.
the lower right shows a hollow/convex saber combination, where you essentially have a very large fuller that convexes into a low saberish grind. theres some pretty weird stuff you can do, but still maintain visual clarity in whats happening on the blade surface.
I'm pretty sure the Badgers will be flat ground.
Here's a quote right below the picture of the Limited:
[FONT=Arial,Helvetica,Geneva,Swiss,SunSans-Regular] Limited Edition's .25" thick blade has a satin finish, full height flat grind and Tiger Hide handles. Price: $397[/FONT]
the standard model has the same high to full convex grind at 3/16" thick as the standard satin jack. the limited edition model will be a full flat grind at 1/4" thick.
I kinda wish they had offered the hogsjtack in full flat or possibly the same high saber as the 3rd gen edition.
[edit: this information is incorrect, both editions of the badger attack will in fact (as per jerry) be flat ground {2:15pm 4/6/2007}]
Would you call a full-height convex edge/grind the same as "zero edge" geometry?
I never saw Jerry post anything about the Badger being a full convex. It's flat with saber on the CG and full flat on the LE. Look at the pic of the CG BATAC on the website. The plungeline is straight and not progressive as would be expected from a convex grind. The BATAC does not have a convex primary. It seems people (not LVC lol) are still confused about primary and secondary grinds. The primary is the BIG one. The secondary grind is the edge or bevel. I would defer to LVC on blade geometry understanding every day of the week but I think there is some confusion on the Badger design. The BATAC is not just a shorter SJTAC. The flat grind is another distinction between the two.
From what I understand a true zero edge just lacks a secondary grind or bevel. The primary grind goes all the way to the edge. This thinness behind the edge is one of the reasons this grind is supposed to be wicked sharp. This type of edge can be accomplished from a convex or flat primary grind. The SJTACLE for example had a full convex primary but still had a bevel on it which I believe was convex as well as Jerry said he is doing only convex edges unless otherwise requested. Some of my Busse's look like a flat bevel ("V") but maybe that's "convex on very tight belts" appearing and in effect serving as a flat or "V" bevel. "Zero edge" is a better description of edge geometry that grind geometry.
That is all great info but again my ignorance showing: Would the actual grind on the Badger make a very noticeable difference for someone that is not a highly sophisticated user/tester?
Knowing that the Busses are highly well made and designed does it make much difference if the Badger is a flat grind, or a sabre, or a convex in actual usage?
There will be near zero difference. What are we comparing? It sounds like we are comparing a knife in a form it will come in with one it will NOT be available in. Flat ground is going to be a little slicier in use than convex and I'm pretty sure it is coming in flat. Don't worry about the technicalities... just don't miss ordering one lol.
Jerry has always chosen the same primary grind angle on the CG and LE versions (also read thinner vs. thicker). In a deep cut there will be a little more friction on the LE versions due to their thickness.
...AND if you like to hike, the BATAC will be an OUTSTANDING knife to have on you :D :thumbup:
