<font face="Verdana, Arial" size="2">Originally posted by Cut-Up:
What holds the ball detent in place?</font>
<font face="Verdana, Arial" size="2">Will it ever fall out? Does it actually roll around or does it just act as smooth sliding surface</font>
<font face="Verdana, Arial" size="2">Originally posted by Paul Davidson:
The ball detent is mainly to hold the blade closed. It should not be moving around. It's just a tiny ball bearing inserted into a whole. The edge of the hole is then peened (not sure if that is the proper term here) to tighten the hold on the ball bearing. When you take your Sebenza apart you will notice a small dent next to the ball detent which is the result of this. Hope this helps.
</font>
<font face="Verdana, Arial" size="2">Originally posted by stjames:
I think you have a good chance of "smoothing" the bearing to the point that it doesn't do its job; keeping the blade secured in the closed position. This will result in a trip back to Boise for the knife and a cost to you to get the knife working properly.
Lots of lubes to try before you start fiddling with the ball detent, don't you think?
</font>
