I'm happy to clear up your confusion.
There is a very
big difference seen when the substrate is hard or soft, i.e. mouse pad vs MDF. That should be obvious.
But it doesn't matter
which hard substrate or
which soft substrate, so
no difference between different soft substrates and
no difference between different hard substrates. Within reason, of course. Stropping on a soft substrate made from fresh Playdough will be quite different from stropping on a soft substrate of mouse pad.
This can be seen clearly when using a soft mouse pad as a substrate and creating a convex edge compared with using something hard such as MDF, and creating a good stropping surface for a beveled edge. Instead of the mouse pad one could use a a soft thick suede leather. It doesn't matter as long as it's soft. Instead of the MDF one could use firm leather, a paint stirring stick, etc. It doesn't matter as long as it's hard.
I have now. I don't find any difference. As long as one is using normal light stropping pressure, only the surface of the compound is being contacted so there is no difference between the substrates.
If someone strops with a very heavy hand, and uses tangent grain cut balsa, they will compress the wood. If they use quarter grain cut they will compress the wood to a lesser degree. If they use end grain or random grain cut adjusted to a grain-on surface, they will need a very heavy hand indeed to compress the wood but it can be done. But then, that's not how to properly strop an edge.
Stitchawl
