Band saw speeds
I hope that someone can tell me what the proper speeds for cutting
O-1 1/4" and less
stainless 1/8" and less
titanium 1/8" and less
And some suggestions on teeth per inch.
Thanks,
Garrett
Garret
I would use a 16 or 18 tooth blade for these materials. Use the recommended speed from the manufacturer. Most will give you there take on the blade and material your cutting .
Heres a number for some good folks that can help
SAW SYSTEMS
1800-966-1300 ask for Dwayne
Web Site At www.infinet.com/~browzer/bldesmth.html
Take a look!!!
Thanks Darrel. Glad to see you back. I'll give them a call. My friend says it only goes down to 300 SFPM. I don't think that is slow enough.
Thanks again,
Garrett
Saw an amazing demo at J. Stout's Hammer-In last weekend. Called friction cutting. Use a regular wood-cutting bandsaw and speed it up to 3,000 fpm blade speed.
Johnny uses his old blades that will no longer cut wood and they cut through 3/16 blade stock like crazy. Even with the teeth worn off almost smooth it still cuts with the heat generated by the edge of the blade. I tried it myself and it cuts 5 or 10 times as fast as my regular slow-speed metal cutting bandsaw with a brand new bimetal blade.
Wear gloves and goggles.
Ben R. Ogletree, Jr.
